Which fuse/relay
Old Aug 29, 2006 | 04:33 PM
Stickboy46's Avatar
Stickboy46
Default Which fuse/relay
Ok, i was installing an item behind the radio and i tapped into the radio constant on power for the power. I accidently grounded it out (oops). Now the radio, interior lights (including visor lights), and the headlight dinger do not work. This is a 99 dodge neon. Anyone have any idea which fuse relay, may need to be replaced? Thanks
Ryan
Old Aug 29, 2006 | 05:16 PM
mh1970's Avatar
mh1970
Default RE: Which fuse/relay
its fuse #13 in fuse block under hood by battery,10amp
Old Aug 29, 2006 | 07:17 PM
spudsterier's Avatar
spudsterier
there is also a fuse for the radio on the right side of the dash when you open the door...check that one too....im not sure which one it is, but if you look at the back of the fuse door, then it says
