Code 45????
there is no code 45.... theres 15, 25, 35 ,55, and 65 though...
15 is no speed sensor signal
25 is vacuum leak, ideal idle target not reached (+/- 200rpms), Idle air control motor circuit problem
35 is radiator fan control relay circuit problem
55 is end of errors (as in no more left to show)
65 is power steering switch failure
try to pull the codes again, besides the code is there anything else that is going on, have you noticed a drop in performance or something just doesn't seem right? what kind of car is it as well.
