-Head & Tranny Q-
Old Sep 6, 2006 | 09:41 PM
jdub396's Avatar
jdub396
Default -Head & Tranny Q-
Two questions:
1) What kind of job would it be to swap an auto to a 5 speed....computer issues along with any others????
2) If I were to pull the head off of a SOHC motor, how much could I shave off (get comp. up!!) without running into valve/piston ploblems (hitting each other)....I'll likely be putting a slightly bigger cam in.
Thanks!
Old Sep 6, 2006 | 11:56 PM
spudsterier's Avatar
spudsterier
Default RE: -Head & Tranny Q-
swapping the tranny isnt that bad.....and just get a pcm out of a manul and all your problems are solved
Old Sep 7, 2006 | 01:30 AM
das2123's Avatar
das2123
1)Here is a website that has a great tranny swap how-to, so you can see what you are in for...
http://www.msu.edu/~lareseer/trannySwap.html
2).025" would be the max I think.
Old Sep 8, 2006 | 07:51 PM
jdub396's Avatar
jdub396
Sounds like a pain in the A**..... What if I would find a DOHC 5-speed neon and swap motors (I have to run a Single cam motor)? Would that be any easier?
Old Sep 8, 2006 | 08:32 PM
das2123's Avatar
das2123
You can swap motors, but I don't know that it will be any easier. In the how-to on that web page they left the motor in, but I'd pull the motor and tranny together.
