Dohc Turbo
Old Sep 12, 2006 | 06:45 PM
jkgoff2007's Avatar
jkgoff2007
Default Dohc Turbo
"everything" needed to put an srt-4 turbo on 98 dohc
Old Sep 12, 2006 | 07:33 PM
spudsterier's Avatar
spudsterier
Default RE: Dohc Turbo
turbo/manifold
oil/oolant lines/fittings
map clamp
intercooler
intercooler piping
turbo 02 housing
downpipe
boost controler...just a good idea
boost gauge...if you want
fuel pump
fuel pressure regulator
be a good idea:
new oil pump
new water pump
possible engine rebuild....bearings/rings
i plan on getting my turbo goin here pretty soon
Old Sep 12, 2006 | 08:24 PM
das2123's Avatar
das2123
MAP clamp or missing link also.
*edit* You did put Map clamp on there, sorry!
I'd suggest getting a book called Maximum Boost by Corky Bell if you want to build your own turbo it. It is MUCH MORE than just putting the SRT-4 turbo and manifold on there and going!
