engine swapping
Old Sep 17, 2006 | 12:20 PM
matthewdavis6969's Avatar
matthewdavis6969
Default engine swapping
Can i get a list or site or something of all the stuff i would need to switch my 96 auto sohc 2.0 litre neon to a 5 sp. dohc 2.0 litre? and if i wanted to turbo the dohc what all would i need unless its extremely expensive. if it iosnt what would be somje good full engine kits u can buy because i imagine there cheaper then buying stuff seperately....
Old Sep 17, 2006 | 08:48 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: engine swapping
i would immagine a sohc to dohc wouldnt be too awfully hard. but as i always advocate the 2.4T swap if your up for the challange!!!
http://www.dodgetalk.com/forums/showthread.php?t=77268
but to answer your question i did a quick search:
ORIGINAL: RadarLove
...Then there's all the '95-'99 DOHC's if you want, with a few more parts (intake and exhaust manifolds, etc.), and the 2.4L engines out of the Caravan, Stratus, PT Cruiser, etc. for a more fun project (preferably coupled to a turbo).
Best of luck!
Old Sep 18, 2006 | 02:46 AM
das2123's Avatar
das2123
ORIGINAL: matthewdavis6969
Do you want to swap engines or just upgrade your current SOHC to a DOHC?
HERE is a link to a tranny swap how-to.
Hahn Racecraft makes the only turbo kit for our neon and costs about $3000. You can use the turbo and exhaust manifold on the SRT-4 and build your own kit. Look at spudsterier's posts...he is currently working on this one.
Old Sep 19, 2006 | 12:10 AM
rrwertz's Avatar
rrwertz
2.4's are cheap and easy.
might as well swap that in rather than a dohc if you can find one. must be 01 and under though.
here's a pretty comprhensive list for sohc to dohc swap:
Dohc Fuel Rail
Dohc Fuel Line
Dohc Head
Dohc Valves
Dohc PS Reservoir
Dohc PS Lines
Dohc Valve Cover
Dohc Valve Cover Gasket
Dohc Intake Setup
Dohc Intake Manifold
Dohc Upper Radiator Hose
Throttle Body Gasket
Dohc EGR Tube
Dohc Cams
Dohc Cam Gears & Bolts
Dohc Upper Gasket Kit
Dohc Exhaust Manifold
Dohc Heat Shields
Dohc Timing Covers
Dohc Timing Belt
Dohc Thermostat Housing
Dohc Cam Positioning Sensor
Dohc Ignition Wires
Dohc Head Bolts
Dohc Side Motor Mount Bracket
Dohc TPS & IAC
Dohc Idler Pulley
Dohc Hood
Dohc Engine Harness
Dohc 97-99 PCM
