PCM code question
Old Sep 24, 2006 | 09:05 AM
racerx55's Avatar
racerx55
Default PCM code question
ok so my car runs decent, seems a little doggy but i figure its just tired, i got a stored code out of the PCM (check engine light is never on)
27 Injector control circuit
what the hell would that be...
i cleared the codes, it shows up a day later, but the light never comes on,
cycle the key it'll flash the codes so i know it works... maybe the PCM is takin a crap its been doin some goofy **** lately
Old Sep 25, 2006 | 03:26 PM
das2123's Avatar
das2123
Default RE: PCM code question
Check the connection to each injector on the wiring harness. Maybe one has come loose and/or is broke.
Old Sep 25, 2006 | 04:42 PM
tomthedog's Avatar
tomthedog
not ALL codes will cause the CEL to light. looking over my book, it seems to me if you can tell something is wrong (it runs just a bit bad or it won't start) the CEL won't come on.
Old Sep 26, 2006 | 12:31 PM
racerx55's Avatar
racerx55
runs fine still, starts right up, code still comes back so who knows, one injector checked way out of spec with ohms, changed it with a spare, that got rid of the off-throttle miss, cleared the codes and it still comes back, who knows run it till it dies
