no rpm's
Old Sep 27, 2006 | 04:27 PM
mmench's Avatar
mmench
Default no rpm's
ok i read the post already on here and my problem is similar. but i have just replaced the map sensor because i to had the number 14 code. however i cant go past 4k and at bout 1/4 throttle it almost dies. if i reset the computer , start it back up and rev it all the way it will hit the real redline at like 6700rpms. but when i let off a sec or two later it sputters and fumbles all over. also after that if i start it up it almost dies and i gota play with the gas to keep it running for a few secs then it smooths out and idles.HELP!!!
Old Sep 27, 2006 | 04:29 PM
spudsterier's Avatar
spudsterier
Default RE: no rpm's
it reall sounds like you timing might be a tooth off.....maybe it jumped one
Old Sep 27, 2006 | 04:46 PM
mmench's Avatar
mmench
how do i check that though. and if that did happen would it still rev all the way one time after the comp is reset and would it idle ok
Old Sep 27, 2006 | 07:31 PM
spudsterier
all depends....i had a car that had bad timing and it would idle real good once and a while....but starting it was a pain, you had to almost floor it the whole time while cranking.....maybe its just a little off, maybe thats not your problem at all....
sumone else can tell you how to check your timing
Old Sep 28, 2006 | 06:00 AM
racerx55's Avatar
racerx55
could possibly be a throttle position sensor going haywire
are you getting any more codes?
