Codes
Old Oct 9, 2006 | 12:08 AM
lateralus823's Avatar
lateralus823
Default Codes
Okay so my check engine lights been on, no big deal, my dad punched out the stuff in it for some stupid reason. I got the codes 12, 11, 27, 43, and 31. I havn't the slightest clue what any of these could mean, and i was wondering if someone could possibly help me out? thanks.
Old Oct 9, 2006 | 12:29 AM
ZiggyNeon's Avatar
ZiggyNeon
Default RE: Codes
check these
CEL
CEL 2
you should check out the 1st Gen FAQ post in the top section
Old Oct 9, 2006 | 12:51 AM
lateralus823
Default RE: Codes
The thing thats weird is im not having any problems what so ever with the car. the only problem is that the acceleration from 1st gear to 2nd is as quick as it should be and its only reving to around 5000 rpms when i floor it at a dead stop.
Old Oct 9, 2006 | 02:17 AM
xdeathwishx's Avatar
xdeathwishx
Default RE: Codes
i bet if you fix that timing belt it will at least make the 43 code go away along with the 11.
Old Oct 9, 2006 | 11:46 AM
lateralus823
Default RE: Codes
How much roughly would it cost to get the timing belt changed?
Old Oct 9, 2006 | 12:08 PM
das2123's Avatar
das2123
Default RE: Codes
Reset the PCM and see what codes come back. The code 43 is usually sprak plugs and/or wires need to be changed.
