Cheap Headers....worth it?
Old Oct 19, 2006 | 11:31 AM
99 Neon's Avatar
99 Neon
Default Cheap Headers....worth it?
i found these headers for 100 dollars and im just wondering are they worth it?
http://us.st11.yimg.com/us.st.yimg.c..._1918_73355671
Description:
All DC style headers are made from stainless steel mandrel bent pipes and investment casted flanges. Main power improvements are made by the design and placement of the collectors to even out the exhaust pulses. Large primary runners make it a solid choice for your vehicle. Realize your motor full potential. Designed to make power from 4000 RPM to redline without loosing any power on the bottom end. This header is second to none when it comes to performance. This design allows for lighter weight and a cleaner look. 8-12 hp average gain.
Old Oct 19, 2006 | 01:16 PM
das2123's Avatar
das2123
Default RE: Cheap Headers....worth it?
First of all, its a header (singular), not headers (plural) ...And it would be a step up from stock but since you have a DOHC, a longtube header would be WAY BETTER.
Old Oct 20, 2006 | 02:03 AM
99 Neon's Avatar
99 Neon
ORIGINAL: das2123
care to point me in the right direction? =]
Old Oct 20, 2006 | 02:55 AM
das2123's Avatar
das2123
ORIGINAL: 99 Neon
ORIGINAL: das2123
Kirk Header which you can't use the cat or MPx Header which you can keep your cat.
