next performance mod to look for?
Old Oct 23, 2006 | 11:35 PM
spudsterier's Avatar
spudsterier
Default RE: next performence mod to look for?
i like spinngin donuts....the screech they make is awsome..and the 2 inch wide black marks are pretty cool
i can spin a set of those things down the street
Old Oct 23, 2006 | 11:42 PM
Racingvon's Avatar
Racingvon
Default RE: next performance mod to look for?
Long tube headers would be good. I don't know if $200 dollars is expensive to you though.
Old Oct 24, 2006 | 01:16 AM
99 Neon's Avatar
99 Neon
i have a standard =] and 15in rims on at the moment i was looking into getting 16inch not much of a diffrence and yes smaller tires = faster acceleration. and my cold air only makes it a tiny bit faster nothing noticeable but on a good note it sounds amazing =]
Old Oct 24, 2006 | 02:03 AM
das2123's Avatar
das2123
ORIGINAL: 99 Neon
Not on bigger rims they don't. It doesn't mater if the overall diamter is the same as stock. If the rim is bigger, it WILL slow down acceleration.
Old Oct 24, 2006 | 09:33 AM
spudsterier
ORIGINAL: das2123
i seem to lack the knowledge of how this works out[&:]
Old Oct 24, 2006 | 12:19 PM
das2123's Avatar
das2123
ORIGINAL: spudsterier
ORIGINAL: das2123
Inertia is the reason spud.
Old Oct 24, 2006 | 04:27 PM
spudsterier
ok, but how.....if its the same overall diameter and same weight...then why would it be slower???
Old Oct 24, 2006 | 04:46 PM
das2123's Avatar
das2123
On a smaller rim, more of the weight is close to the center. As the rim gets bigger, more of the weight of the rim gets closer to the outer part. This makes it more difficult to turn.
Old Oct 24, 2006 | 07:04 PM
spudsterier
well i guess i can understand that a little more
