Rough idle on 97 with DOHC
Old Oct 23, 2006 | 06:08 PM
treeboa's Avatar
treeboa
Default Rough idle on 97 with DOHC
My Neon is idling rough then acting like it's not getting enough gas on takeoff. It's not doing it all the time, I'd say about half the time. Any Ideas?
Jeff
Old Oct 23, 2006 | 07:08 PM
das2123's Avatar
das2123
Default RE: Rough idle on 97 with DOHC
Could be alot of things...plugs/wires/coil pack, EGR valve, fuel pump. Is your CEL on?
Old Oct 23, 2006 | 07:31 PM
treeboa's Avatar
treeboa
Yes the CEL is on.
Old Oct 23, 2006 | 07:40 PM
das2123's Avatar
das2123
ORIGINAL: treeboa
Yes the CEL is on.
Pull the codes. HERE is how you do it.
Old Oct 23, 2006 | 08:27 PM
treeboa's Avatar
treeboa
OK I got 37-Torgue converter clutch solenoid CKT or park/neutral switch failure and 21 oxygen sensor problem.
jeff
Old Oct 24, 2006 | 12:38 AM
das2123's Avatar
das2123
Check your wiring to your upstream O2 sensor, located on the exhaust manifold, and make sure its OK. If it looks OK, you may need to change it out.
Old Oct 24, 2006 | 04:09 AM
treeboa's Avatar
treeboa
Thanks alot for all your help. I'll let you know how it turns out.
jeff
