97 Dodge neon Died
Old Oct 25, 2006 | 11:09 PM
pooh98's Avatar
pooh98
Default 97 Dodge neon Died
I need some anwsers. My 97 neon died. I was drivin down the road and it started to sputter and then died. Tried to restart, it didnt. Had it towed to a shop, and he checked the cam sensor, the timein belt and another sensor.It told me it was an electric problem. So i had it towed to another shop and they told me I needed a Timein Belt kit, so i went and bought it. They put it on and it fired. Now they are tellin me that my valves (SP) might be bent. From what I heard and know, the only way they can bend is by the timin belt either brakes or skips time. Neither one happen. I guess i need to know if they are tell me the truth or just tryin to get money from me. And maybe if there is anything else that might be the problem?
Old Oct 25, 2006 | 11:18 PM
spudsterier's Avatar
spudsterier
Default RE: 97 Dodge neon Died
are you positive that the timing belt deffinately didnt brake?????
Old Oct 25, 2006 | 11:23 PM
rtneon's Avatar
rtneon
the pin that holds the cam gear in time with the cam might of broke that happen to me and it seemed like my car wanted to sart but it wouldnt have them do a compression test on it and see if that is good
Old Oct 25, 2006 | 11:25 PM
pooh98's Avatar
pooh98
Im positive the timing belt didnt brake, I had someone look at it before i took it to shop thats its in now.
Old Oct 26, 2006 | 12:43 PM
das2123's Avatar
das2123
ORIGINAL: pooh98
You can also bend valves if it skips a tooth. Have the compression checked to see if the valves are bent.
