Ahoy!
ebay is probally your best bet....get the motor and trans with everything needed for about 2000-3000....but if your gonna swap it out, then your best bet is to spend about 6,000 on a whole recked srt4, then you have all the parts needed
Various reason, like with any other swap you may need parts here and there from the SRT-4 car. might decide to splice the harness if you don't want to try to find a new one, might decide to put the SRT-4 rims on, plus in some yards it could just be cheaper, some yards might charge you more just for the motor vs the entire car plus if you do need some other stuff you wouldn't have to return and get those things, they would be at your finger tips, not only that but your lucky to find one period and if you don't get the parts while you can, they may not be there when you go back. basically like spud said, all the parts you would need except things like megasquirt are included
unless you decide to use an engine management system, then you will need to get the srt4 wire harness, pcm, gauge cluster, ignition.....misc. things....if you are gonna use the srt4 tranny, then you will probally need the cross member, struts, spindles, half shafts.....
