SRT Turbo Checklist
i dont wanna find a place to dyno it until the motor gets done......hopefully in about a month
plu with the problems i have now, it wont make it to the dyno even if i find one[:@]but i will put up a different post about that
i just got the hot and cold side pipes because they are rubber, so it makes it easier to start with from the intercooler.....basically, i used part of the srt hot side pipe to mount to the intercooler and from the end of that pipe, i used the aluminum 2.5 pipe all the way to the turbo....then for the cold side i chopped up the srt hose so that all i had was the L bend since the opening on the intercooler is oval....then from there to the throttle body i used more of the 2.5 pipe......
basically you dont need them, but it makes things a little easier
