EGR
Old Nov 3, 2006 | 12:35 AM
Chris2121's Avatar
Chris2121
Default EGR
I just replaced my egr valve, and it still says that its an EGR Flow Problem. I changed the hoses, everthing seems to run good, but i cant pass inspection with the service engine soon light on. Please, i need help fast
Old Nov 3, 2006 | 01:22 AM
spudsterier's Avatar
spudsterier
Default RE: EGR
you probally just need to get the code cleared......once the pcm encounters a problem like that, it will store the code, and the code will not go away until cleared
Old Nov 3, 2006 | 01:39 AM
winsettz's Avatar
winsettz
Default RE: EGR
I think you can clear the code by disconnecting the battery for a long period of time?
Old Nov 3, 2006 | 04:20 AM
jared6180's Avatar
jared6180
Default RE: EGR
5-10 minutes, not that long!
Old Nov 3, 2006 | 10:14 AM
spudsterier
Default RE: EGR
but you only disconnect the positive side
Old Nov 3, 2006 | 12:05 PM
das2123's Avatar
das2123
Default RE: EGR
ORIGINAL: spudsterier
I do the negative side or pull the fuel pump fuse for 10 minutes.
Old Nov 3, 2006 | 12:48 PM
FastNeon84's Avatar
FastNeon84
Default RE: EGR
think i got the same problem too..my SES light is on also and Advance told me it was my EGR solenoid circuit valve or something like that when they did diagnostics.. anyone know how much that problem costs to be fixed?
Old Nov 3, 2006 | 01:00 PM
das2123's Avatar
das2123
Default RE: EGR
The EGR valve and transducer are about $90 from the dealer.
Old Nov 3, 2006 | 03:51 PM
spudsterier
Default RE: EGR
ah, i wasnt sure which it was....just took a shot
