Is it a Blown headgasket?
Old Nov 9, 2006 | 01:40 AM
Youngstown97Sohc's Avatar
Youngstown97Sohc
From: Youngstown , ohio (muder capital per capita u.s. )
Default RE: Is it a Blown headgasket?
my bad , i figured it was exhaust b/c they were all rusty.... my bad..
SPUD : btw , i noticed a tube running from the bottom drivers side to where the battery tray goes... theres some kind of sensor with two wires running to it , and its not attached to anything... any idea what this is...
hova
Old Nov 9, 2006 | 02:10 AM
winsettz's Avatar
winsettz
I believe Neons have a battery tray temperature sensor, used to more accurately gauge battery charge as a function of temperature.
Old Nov 9, 2006 | 02:26 AM
ZiggyNeon's Avatar
ZiggyNeon
ORIGINAL: winsettz
correct the sensor by the batt tray is the batt temp sensor
Old Nov 9, 2006 | 03:35 AM
das2123's Avatar
das2123
ORIGINAL: Youngstown97Sohc
The tube is a battery vent to get fresh air and the other is your battery temp sensor as stated.
Old Nov 9, 2006 | 10:23 AM
spudsterier's Avatar
spudsterier
my tube is gone and the sensor is unplugged....had to do it so i could cut the front of the battery tray off for the intake
Old Nov 9, 2006 | 10:03 PM
Youngstown97Sohc
so this isnt going to screw anything up then....and i can remove all that and make a ram air to go in place of it?
did you get a check engine light by cutting the sensor , or no?
hova
Old Nov 9, 2006 | 11:29 PM
das2123's Avatar
das2123
Yes you can.
You won't get a CEL, but your battery light may pop on.
Old Nov 10, 2006 | 12:15 AM
Youngstown97Sohc
lol... i think ill just duct tape it down... i dont want any crazy *** battery light on , seeing as how my ground terminal is loose....
then again i could just fix the loose terminal....but i probably wont...
hova
Old Nov 10, 2006 | 01:13 AM
spudsterier
i havent seen my battery light yet
Old Nov 10, 2006 | 02:49 AM
neonboy07's Avatar
neonboy07
dont think it is your head gasket it would over heat or have like milk in your oil and some times it would spit and spudder really bad or it would have white under oil cap is it kicking a check engine code?
