steering
Old Nov 11, 2006 | 04:00 PM
IGottaFreeNeon's Avatar
IGottaFreeNeon
Default RE: steering
I've been thinking about removing my power steering pump. Could this cause any harm? Would I gain back any horsepower? Is it worth the time? I'm mainly looking to free up some horsepower and maybe shed some weight. I only thought about it because it makes an obnoxious sound sometimes and I know it's going to fail eventually.
Old Nov 11, 2006 | 09:00 PM
das2123's Avatar
das2123
Remove the line and the pump and its feels better. If you just remove the belt, its a PITA to turn, but if you remove everything, it's not so bad. Better feel for the road also.
Old Nov 11, 2006 | 09:36 PM
Allnbrgdn1's Avatar
Allnbrgdn1
so now the poer steering works again? what could be the prob?
Old Nov 12, 2006 | 12:51 AM
das2123's Avatar
das2123
ORIGINAL: Allnbrgdn1
Probably a loose belt.
Old Nov 12, 2006 | 02:35 AM
HabitatHxC's Avatar
HabitatHxC
My friend was telling me that i should put my belt back on mine, because the rack and pinion thing should have fluid goin through it... and without the pump pumping... it has none and can cause problems... True or false or both?
In reply to the above... IT actually could be the AC is locked up and its keeping the belt from spinning... that was the problem with mine when my ex had the car... So we took out the AC and every thing was peachy!
Old Nov 12, 2006 | 02:49 AM
das2123's Avatar
das2123
ORIGINAL: HabitatHxC
False.
