need to know
Old Nov 12, 2006 | 10:41 PM
das2123's Avatar
das2123
Default RE: need to know
ORIGINAL: tEamnEon
by the way how much would the turbo cost me???????????
About $200-$300 for the manifold and turbo. If you have a DOHC engine it will bolt right up, if you have a SOHC then you will need an adapter plate. You will need more than just the turbo/manifold though. Look at THIS post for more info.
Old Nov 12, 2006 | 11:23 PM
spudsterier's Avatar
spudsterier
it is very possible
[IMG]local://upfiles/29901/0929A711F0DC4961AA0881F5949345B4.jpg[/IMG]
Old Nov 13, 2006 | 12:32 AM
tEamnEon's Avatar
tEamnEon
i dont know if its dohc or sohc i just know that it has duel over head cams does that mean im gonna nee the adapter for the turbo??
Old Nov 13, 2006 | 12:40 AM
racerx55's Avatar
racerx55
DOHC=Dual Over Head Cam
SOHC=Single Over Head Cam
Old Nov 13, 2006 | 12:48 AM
das2123's Avatar
das2123
ORIGINAL: tEamnEon
You won't need an adapter since you have the DOHC engine.
Old Nov 13, 2006 | 10:40 AM
spudsterier
the turbo bolts right up to a DOHC...but there are 2 bolt holes on the manifold that dont bolt to the head.....but i havent seen any problems with that yet....
the project isnt that bad to do.....only thing ive seen to suck so far is having the return fuel line put into the fuel pump...luckily im not doin that part(but sumone else is)
