Dash Removal
Old Nov 11, 2006 | 08:33 PM
Ozneon's Avatar
Ozneon
Default Dash Removal
Want to pull the dash complete from the right hand drive neon tell me were to start and finish please.
I parting it out but still want to remove things in 1 peace cheers
Old Nov 11, 2006 | 09:26 PM
spudsterier's Avatar
spudsterier
Default RE: Dash Removal
the entire dash assembly?????
i think that you actually have to take some of it off piece by piece....but anyways, if you remove the center console then you will find 2 bolts on either side about 6 inches infront of the shifter....
then if you remove the plastic trim on the bottom of the dash there are 2 bolts on either side by the top door hinge....
it sounds confusing, but it isnt that bad
Old Nov 11, 2006 | 09:56 PM
Ozneon's Avatar
Ozneon
Im taking it out in peaces dash top/facer panels/stereo/ it getting there slowly just a dam hot day again on the Goldcoast which ant helping.
Old Nov 12, 2006 | 12:46 AM
das2123's Avatar
das2123
The top part of the dash, just pops off. The rest is held in by screws.
Old Nov 12, 2006 | 06:46 AM
Ozneon's Avatar
Ozneon
Got stuck on the air bag passenger side has 2 nuts that are located in the glove box only thing that was holding me up
to remove it
