seafoam
Old Nov 15, 2006 | 09:28 PM
  #21
pimpberetta's Avatar
pimpberetta
Default RE: seafoam
I have been running that seafoam in the oil for about 2000 km's now. It didnt say anythign about dumping it right away.
I added maybe half the can. Where did you learn about having to dump it right away? I thought it was to stay and clean it up while it is in there??
Old Nov 15, 2006 | 09:42 PM
  #22
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: seafoam
Seafoam's best benefit's are realized by older vehicles that haven't been run on "top tier" gasolines like Chevron or Texaco.....if you've been using top tier gasoline for your car, Seafoam is a waste of money........
Dusty
Old Nov 15, 2006 | 09:50 PM
  #23
FyreDaug's Avatar
FyreDaug
Default RE: seafoam
ORIGINAL: pimpberetta
oh **** dude, that stuff is basically just isoproyl alcohol, some octane booster and something else. It is not oil soluble. Change that **** immediately your oil is probably breaking down and not lubricating properly. Its only meant to be used temporarily to "grab" some of the oily carbon **** inside your oil pan and stuff, it says it cleans out oil passages aswell. Its probably gunked up your oil filter too. You are really only supposed to use it as a "motor flush" if anyways
Old Nov 15, 2006 | 09:55 PM
  #24
FyreDaug's Avatar
FyreDaug
Default RE: seafoam
ORIGINAL: dustyloins
Dusty
thats part true, though spraying throught the throttle body will do more cleaning than just the gas will. Itll clean out the IM, some of the TB, maybe get a little gunk from the EGR. And it does better on the intake valve side aswell, since its not under pressure it flows in with the air it moves slower and grabs anything on the intake valve better than the gas does. Though I do agree that top tier gas is the way to go. Our SHELL has that up here and thats all I use, I still have to say that seafoam has its benefits
Old Nov 15, 2006 | 10:09 PM
  #25
das2123's Avatar
das2123
Default RE: seafoam
ORIGINAL: FyreDaug
Vulgar language is not permitted on these forums, keep it clean
Old Nov 15, 2006 | 10:11 PM
  #26
FyreDaug's Avatar
FyreDaug
Default RE: seafoam
I thought there were swear filters in place for that, and the words that werent filtered were fine to use. like any other normal forum
Old Nov 15, 2006 | 10:20 PM
  #27
das2123's Avatar
das2123
Default RE: seafoam
ORIGINAL: FyreDaug
Rule #1
Vulgar language, images and other offensive material including, but not limited to, race, nudity or pornography is not tolerated here. The Dodge Forum staff shall be the sole judges of what does and what does not violate the boards standards.
We clear?
Old Nov 15, 2006 | 10:24 PM
  #28
FyreDaug's Avatar
FyreDaug
Default RE: seafoam
aslong as your clear that there are swear filters you can add, the "F" word is sensored
