neon wiring
Old Nov 18, 2006 | 06:41 PM
burntricer's Avatar
burntricer
Default neon wiring
hey guys, im having a n issue with my neon (no not that its a neon, although that is the biggest problem) i was trying to fix some idiots mistake when he wired in the old deck that was in it, now i put the stocker back in wired correctly and i blew 3 fuses, so i replaced them with no problems and now i still have no radio, or door chime.
the fuses i blew were for the radio, gauge lighting and interior lighting, is there a possibility that the door chime has a module that i blew up? or??? im stumped and driving without a radio SUCKS
Old Nov 18, 2006 | 06:48 PM
JDC420's Avatar
JDC420
Default RE: neon wiring
It sounds weird but check your dome light fuse under the hood. Check all your fuses for that matter. When my domelight fuse goes the radio goes.
Old Nov 18, 2006 | 06:50 PM
spudsterier's Avatar
spudsterier
are you sure the radio is wired up right???? maybe the illumintaion wire is crossed with the power or ground wires
Old Nov 18, 2006 | 06:55 PM
burntricer's Avatar
burntricer
ORIGINAL: JDC420
all the fuses are good, and the harnesses are wired correctly...
Old Nov 18, 2006 | 10:05 PM
iwalton63's Avatar
iwalton63
make sure that all your connections to the deck are good ones ( meaning all the wire part is either taped or cover witha wire nut)
I had the same problem with mine. When i bought the car the guy told me that the taillights, gauges,and the dash lights werent work.
I couldnt figure it out at first but it was because the orange wire on the stereo was touching metal. It also had blown fuses.
so yeah just make sure all the wires to the stereo are good and coverd.
