Unsuccessful oil pan gasket replacement
Old Nov 18, 2006 | 11:16 PM
press1280's Avatar
press1280
Default Unsuccessful oil pan gasket replacement
Well just put in the gasket a few weeks ago,it looks to be leaking again at the same spot as before(in the corner where the surface is split-there's some component there and I can't think of the nameof it right now). I did put some RTV in between. Question is is can I put some more RTV in there,or by pulling the pan back out the gasket needs replacement again. Also is there a particular bolt pattern(I just kind of cris-crossed it)?
Old Nov 18, 2006 | 11:58 PM
spudsterier's Avatar
spudsterier
Default RE: Unsuccessful oil pan gasket replacement
there is a specific way to tighten them but i cant remember what it is......das does though
you might be able to add some more silicone in there....dont know if it will help out or not.....
is it leaking from by the seam for the oil pump???
Old Nov 19, 2006 | 01:12 AM
ewetho's Avatar
ewetho
If a seem is leaking then just clean it thoroughly with brake clean let dry. Then apply RTV over seam and pressing as much as possible. Then reapply. Then spray(lightly) with water to set.
Old Nov 19, 2006 | 10:32 AM
spudsterier
clean it with a good wire brush too
Old Nov 19, 2006 | 12:39 PM
press1280's Avatar
press1280
It is leaking at that seam. I did clean the surface with acetone originally. I'll try to add some more RTV, I guess there's nothing to lose at this point.
Old Nov 20, 2006 | 01:54 PM
press1280's Avatar
press1280
Just got a better look,there's a ton of oil on top of where the pan sits,so it's definitely possible it's coming from the cam seal. That'll have to be done also.
