problem?
Old Nov 19, 2006 | 03:55 PM
ohioguru's Avatar
ohioguru
Default problem?
i just finished hooking up a tac on my car it didnt have one before and its a manual.....but it shows the right rpms when idiling but when i get to 3000 it stops acceling (just kinda dies).....is this right cause i dont think it is but im not sure.....and what should i do?
Old Nov 19, 2006 | 03:59 PM
spudsterier's Avatar
spudsterier
Default RE: problem?
is the tach a universal????? it might need to be set for a 4cyl....
i had an autometer in my car a while back and always wondered why it was so off...then i was looking at a new one on ebay and it said what the wires hanging out the back were for...so i cut both of them and it worked great
Old Nov 19, 2006 | 08:44 PM
ohioguru's Avatar
ohioguru
yea its universial and its a autometer.....which wires?
Old Nov 19, 2006 | 09:17 PM
das2123's Avatar
das2123
ORIGINAL: ohioguru
Is it set for a 4 cyl engine?
Old Nov 19, 2006 | 10:51 PM
spudsterier
if it isnt set for a 4cyl. then you have to cut the 2 wires that loop out the little hole in the bak by the power and signal wires
Old Nov 20, 2006 | 04:34 PM
ohioguru's Avatar
ohioguru
i have the autometer sport comp gauge...i only see the red, green, white, and black wires is it one of thoes?
Old Nov 20, 2006 | 11:41 PM
spudsterier
not sure...there should be the wire that you listed comming out of the back...but there should also be 2 small wires that loop out then back in....
unless your has pins on it that you have to adjust?????
do you have a pic of the back of it????
