where can i get a engine cheap at?
Old Nov 23, 2006 | 11:37 PM
bmxer522003's Avatar
bmxer522003
Default where can i get a engine cheap at?
i have a 95 neon sohc n im plannin on puttin a newer engine in it like 96- 98 dohc but i also need a wiring harness n computer n what not does ne one know where i can get one pretty cheap with all that stuff if so pllzzzzz send a link or sum
Old Nov 24, 2006 | 12:50 AM
winsettz's Avatar
winsettz
Default RE: where can i get a engine cheap at?
Couldn't you just swap the SOHC to a '95 DOHC to avoid possible wiring headaches? I think the Neons had a few little changes from 95 to the rest of 1G...the fuel tank setup is one example but I dunno if they changed much in the engine bay.
Old Nov 24, 2006 | 01:57 AM
bmxer522003
i want suthin after a 95 cuz ne 95 is harder to get n usually more expensive atleast here it is i want sum redily available so yeah thats why im not but u know anywhere cheap i could get sum?
Old Nov 24, 2006 | 05:11 AM
95neonriceeater's Avatar
95neonriceeater
go to a junkyard/pick-n-pull
probably at the most you'll pay 500
Old Nov 24, 2006 | 03:18 PM
das2123's Avatar
das2123
www.car-part.com
