map clamp question
Old Nov 30, 2006 | 04:26 PM
spudsterier's Avatar
spudsterier
Default map clamp question
i got the AOBE map clamp and it has 3 wires comming out of it....reb/black/white
does anyone know which color wires these hook up to on the sensor?????
Old Nov 30, 2006 | 05:26 PM
das2123's Avatar
das2123
Default RE: map clamp question
Hope these pic's help....
[IMG]local://upfiles/33897/A54C6618D95E4152A3519016FE5EDE25.jpg[/IMG]
[IMG]local://upfiles/33897/EF4A18FD990246EE8F94B8A92CB2EB45.jpg[/IMG]
Old Nov 30, 2006 | 07:46 PM
spudsterier
my problem is that i dont know which color wires on the sensor the clamp goes too......and i cant clearly see which wires in the pic....would those be the same as on my car????
Old Nov 30, 2006 | 08:25 PM
das2123's Avatar
das2123
OK, according to my 99 FSM here are the color wires:
MAP sensor signal = Dark Green w/Red tracer
Sensor Ground = Black w/Light Blue tracer
5V Supply = Violet w/White tracer
Old Nov 30, 2006 | 08:34 PM
spudsterier
ok that should work.....i think im gonna go and hook it up in a few minuites....
Old Nov 30, 2006 | 09:00 PM
FastNeon84's Avatar
FastNeon84
you gonna go get it tuned when you are finished?
Old Nov 30, 2006 | 10:58 PM
spudsterier
well i got the map clamp hooked up.....i extended the wires and the little box sits by the pcm, that way its somewhat away from heat.
the guy down the street from me is gonna help tune it when its all done
Old Nov 30, 2006 | 11:10 PM
das2123's Avatar
das2123
Glad to see/hear it's coming along.
Old Nov 30, 2006 | 11:22 PM
spudsterier
i have pics that i will post in a minuite in one of the other threads
