A/C Belt..
dont hit tit with a mallet....
look at the power steering belt......then if you notice the passenger side motor mount, there is a metal plate on the motor that the mount mounts too....the front bracket bolt works as a swivel bolt for the power steering pump.......the bolt is right along the frame rail....if there was tension on the belt, the bolt would be right below it about 3 inches from the pump
ORIGINAL: das2123
I've never had to mess with that bolt.
ORIGINAL: spudsterier
about here
[IMG]local://upfiles/29901/785F1C69943B46179F94D76BE8EA3582.jpg[/IMG]
about here
