OverHeating >:-[
Old Dec 2, 2006 | 09:52 PM
99 Neon's Avatar
99 Neon
Default OverHeating >:-[
well my baby car has a lil overheating problem when it idles for too long and its upsettin as i use to be able to sit and idle for an hour if i wanted to but out of nowhere it overheats when idling. when i turn on the heat it goes back down to normal which maes me think fans but i really dont know. its the only problemi have with my car and i wanna get it resolved
Old Dec 2, 2006 | 11:29 PM
NEONRT98's Avatar
NEONRT98
Default RE: OverHeating >:-[
Well hate to tell you this.. but once one problem starts, others soon follow....
Check these:
Radiator cap (Get a new one, not that much)
Losing antifreeze?
Make sure there is no air in the system
Check all your hoses and such
CHECK YOUR RADIATOR.. These are one of those things that *DO* go out in cars!
Let us know what happens...
Old Dec 3, 2006 | 02:15 AM
winsettz's Avatar
winsettz
I believe radiator gasket problems were linked to eventual HG failure, in accordance with an FAQ on the dot-org.
I think the questions to resolve would be:
-Where is your radiator fluid? Are you low? Are you leaking?
-Are your radiator hoses/caps failing?
-Could radiator fluid simply not be flowing? Clog or dead pump?
-Radiator fluid not being cooled down properly? Fan issue?
Old Dec 3, 2006 | 06:44 AM
jared6180's Avatar
jared6180
whats the build date on your car?
Have you ever replaced the headgasket?
Either way you need to completely flush your system and spend $5 on a new thermostat. Check all hoses and clamps. My first 98 R/T had the same TYPE of problem and replacing the thermostat and flushing the system cleared it up.
Old Dec 3, 2006 | 09:35 PM
99 Neon's Avatar
99 Neon
headgasket was 'supposedly' replaced says my aunt the original owner and i already replaced the thermostat so its not that....thanks for the tips ill try them out
