dashboard rattling
Old Dec 2, 2006 | 10:56 PM
starik's Avatar
starik
Default dashboard rattling
dodge neon factory service manual blows!
to remove the top dashboard cover, do i need to remove any other panels first? what about the guage cluster?
Old Dec 2, 2006 | 11:24 PM
NEONRT98's Avatar
NEONRT98
Default RE: dashboard rattling
Nope! Should pop right off there. Its held on by several clips. Get yourself a Chilton or Haynes manual... Much more detailed haha
Old Dec 3, 2006 | 12:37 AM
ZiggyNeon's Avatar
ZiggyNeon
after you pop the dash pad off look around your gauge cluster you should see 6 or 7 screws holding it in all around it( like 2 on top 1 on each side or 2 and then 2 on bottom)
then after taking the screws out just pull towards you and it should just slide out of the to clips in the back
Old Dec 3, 2006 | 01:52 AM
neoncrazy101's Avatar
neoncrazy101
6 screws....2 on bottom and 4 on the sides... or maybe that was just the 95 hmmm
Old Dec 3, 2006 | 02:29 AM
starik's Avatar
starik
ORIGINAL: NEONRT98
I wish Neon FSM was just less detailed.... except it's plain ridiculously wrong all over the place! Today's example: Picture of a guage cluster is labeled as having a tachometer but actually doesnt. I'm afraid to look in engine section for clearance specs, etc.
Out of the 5 different vehicles i had (jap/euro/amer), i'd say Mitsubishi's has the best FSM.
Old Dec 3, 2006 | 05:39 AM
ZiggyNeon's Avatar
ZiggyNeon
some came with tachs some didnt, there plug an play
Edit: there are 2 on top neoncrazy
