CRX?
Old Dec 9, 2006 | 12:15 PM
  #21
FastNeon84's Avatar
FastNeon84
Default RE: CRX?
ORIGINAL: Dazzellerr
sohc 95's dont run 16's stock, sorry. i have one, and stock it ran 17.8. i got it down to a 16.2 with 1k into it. the neon will win for sure, stock hp @ crank is 132. crx is at 98.
3 days after i bought my car, i took it to the track and ran a 16.3...nothing done to it...not even a CAI or exhaust.
Old Dec 9, 2006 | 03:01 PM
  #22
das2123's Avatar
das2123
Default RE: CRX?
so maybe your "friends" were in coupes? or not bone stock?
One was a bone stock coupe, the other was a sedan. It can run mid-16's stock.
Old Dec 10, 2006 | 02:06 PM
  #23
ohioguru's Avatar
ohioguru
Default RE: CRX?
if it helps i have beat a stock civic hatch si with my mtx sohc.......are they all si's?
Old Dec 10, 2006 | 10:36 PM
  #24
mmench's Avatar
mmench
Default RE: CRX?
look. i dont think crx's came with a b18 at all. could be wrong but owel. my friend has a 91 crx si with a b16. they had either a b15 or 16 depending on modle. also the neon will win. i raced my friends crx si mtx with like 2k in mods. i was in a 4dr neon atx with just an intake and no muffler and i won. beat him outa the hole and pulled the whole way.
Old Dec 10, 2006 | 10:44 PM
  #25
mmench's Avatar
mmench
Default RE: CRX?
and civic si's didnt do any better when i raced them
Old Dec 11, 2006 | 06:40 PM
  #26
ohioguru's Avatar
ohioguru
Default RE: CRX?
every civic hatch ive seen or raced hasnt had a b18 but since u can buy this kind of engine then where do they come from?
Old Dec 11, 2006 | 06:47 PM
  #27
QuiK615's Avatar
QuiK615
Default RE: CRX?
can or cant?
Old Dec 11, 2006 | 06:52 PM
  #28
ohioguru's Avatar
ohioguru
Default RE: CRX?
can
Old Dec 12, 2006 | 01:45 AM
  #29
Ghost Neon's Avatar
Ghost Neon
Default RE: CRX?
ORIGINAL: ohioguru
B18 is an integra engine. The B18C is engine in an integra with Vetc feature, or more commonly known as a GSR. The B18C5 is the engine in the Integra Type R.
Old Dec 12, 2006 | 01:55 AM
  #30
das2123's Avatar
das2123
Default RE: CRX?
B18A
* Non-VTEC
* Found in:
o 1986-1989 Accord Aerodeck LXR-S/LX-S (Japan)
o 1986-1989 Accord EXL-S/EX-S (Japan)
o 1986-1989 Vigor MXL-S (Japan)
+ Displacement: 1834 cm3
+ Compression: 9.4:1
+ Dual Keihin Carbs
+ Power: 130 hp (97 kW) @ 6000 rpm & 120 ft·lbf (164 N·m) @ 4000 rpm
+ Transmission: A2N5, E2N5
* This engine is not 100% related to the other B series engines. It is a destroked Honda B20A engine.
B18A1
Non-VTEC
* Found in:
o 1990-1993 Integra RS/LS/GS (DA)
+ Compression: 9.2:1
+ Bore: 81 mm
+ Stroke: 89 mm
+ Power:
# 1990-1991: 130 hp (97 kW) @ 6000 rpm & 121 ft·lbf (164 N·m) @ 5000 rpm
# 1992-1993: 140 hp (104 kW) @ 6300 rpm & 127 ft·lbf (173 N·m) @ 5200 rpm
+ Transmission: YS1
B18B1
* Non-VTEC
* Found in:
o 1994-2001 Acura Integra "RS/LS/GS" (DC4)
+ Displacement: 1834 cc
+ Bore: 81 mm
+ Stroke: 89 mm
+ Power:
# 142 hp (104 kW) @ 6300 rpm & 128 ft·lbf @ 5200 rpm
+ Transmission: S80
B18C
* VTEC
* Found in:
o 1994 Honda Integra SiR-G
o 1995-1997 Honda Integra SiR
* Power: 180 hp (128 kW)
o 1997-2001 Honda Integra (Japan) Type R
* Power: 200 hp @ 8100 rpm
B18C1
* VTEC
* Found in:
o 1994-2001 Integra GS-R (DC2)
* Displacement: 1797 cm3
* Compression: 10.0:1
* Power: 184hp (127 kW) @ 7600 rpm & 128 ft·lbf (174 N·m) @ 6200 rpm
* Transmission: Y80
B18C3
* VTEC
* Found in:
o 1995-1998 Acura Integra Type R
Power: 185 hp
B18C4
* VTEC
* Found in:
o 1996-2000 UK Civic 1.8i VTi Acura Integra
* Power: 169 hp (124 kW) @ 8000 rpm & 129 ft·lbf (174 N·m) @ 7500 rpm
* Transmission: S9B
B18C5
* VTEC
* Found in:
o 1997-2001 Integra Type-R
* Compression: 11.0:1
* Power: 195 hp (145 kW) @ 8000 rpm & 130 ft·lbf (176 N·m) @ 7500 rpm
* Transmission: S80
B18C6
* VTEC
* Found in:
o 1998-2001 Honda Integra Type Rx
* Power: 200 hp (149 kW), 136 ft·lbf
B18C7
* VTEC
* Found in:
o 1996- Honda Integra Type R (Australia)
* Power: 210 hp (149 kW), 136 ft·lbf
