CRX?
Old Dec 12, 2006 | 10:23 AM
  #31
spudsterier's Avatar
spudsterier
Default RE: CRX?
damn, good thing the neons only have 2 engines
Old Dec 12, 2006 | 11:36 AM
  #32
das2123's Avatar
das2123
Default RE: CRX?
ORIGINAL: spudsterier
4, if you throw in the Magnum and SRT-4
Old Dec 12, 2006 | 11:49 AM
  #33
QuiK615's Avatar
QuiK615
Default RE: CRX?
someone told me the SRT-4 engine was the same and the .4 was just the turbo???
Old Dec 12, 2006 | 12:18 PM
  #34
das2123's Avatar
das2123
Default RE: CRX?
ORIGINAL: QuiK615
The SRT-4 engine is a 2.4L engine...not a 2.0L like the SOHC and DOHC engine.
Old Dec 12, 2006 | 01:03 PM
  #35
hnda8r's Avatar
hnda8r
Default RE: CRX?
ORIGINAL: das2123
B18A
* Non-VTEC
* Found in:
o 1986-1989 Accord Aerodeck LXR-S/LX-S (Japan)
o 1986-1989 Accord EXL-S/EX-S (Japan)
o 1986-1989 Vigor MXL-S (Japan)
+ Displacement: 1834 cm3
+ Compression: 9.4:1
+ Dual Keihin Carbs
+ Power: 130 hp (97 kW) @ 6000 rpm & 120 ft·lbf (164 N·m) @ 4000 rpm
+ Transmission: A2N5, E2N5
* This engine is not 100% related to the other B series engines. It is a destroked Honda B20A engine.
B18A1
Non-VTEC
* Found in:
o 1990-1993 Integra RS/LS/GS (DA)
+ Compression: 9.2:1
+ Bore: 81 mm
+ Stroke: 89 mm
+ Power:
# 1990-1991: 130 hp (97 kW) @ 6000 rpm & 121 ft·lbf (164 N·m) @ 5000 rpm
# 1992-1993: 140 hp (104 kW) @ 6300 rpm & 127 ft·lbf (173 N·m) @ 5200 rpm
+ Transmission: YS1
B18B1
* Non-VTEC
* Found in:
o 1994-2001 Acura Integra "RS/LS/GS" (DC4)
+ Displacement: 1834 cc
+ Bore: 81 mm
+ Stroke: 89 mm
+ Power:
# 142 hp (104 kW) @ 6300 rpm & 128 ft·lbf @ 5200 rpm
+ Transmission: S80
B18C
* VTEC
* Found in:
o 1994 Honda Integra SiR-G
o 1995-1997 Honda Integra SiR
* Power: 180 hp (128 kW)
o 1997-2001 Honda Integra (Japan) Type R
* Power: 200 hp @ 8100 rpm
B18C1
* VTEC
* Found in:
o 1994-2001 Integra GS-R (DC2)
* Displacement: 1797 cm3
* Compression: 10.0:1
* Power: 184hp (127 kW) @ 7600 rpm & 128 ft·lbf (174 N·m) @ 6200 rpm
* Transmission: Y80
B18C3
* VTEC
* Found in:
o 1995-1998 Acura Integra Type R
Power: 185 hp
B18C4
* VTEC
* Found in:
o 1996-2000 UK Civic 1.8i VTi Acura Integra
* Power: 169 hp (124 kW) @ 8000 rpm & 129 ft·lbf (174 N·m) @ 7500 rpm
* Transmission: S9B
B18C5
* VTEC
* Found in:
o 1997-2001 Integra Type-R
* Compression: 11.0:1
* Power: 195 hp (145 kW) @ 8000 rpm & 130 ft·lbf (176 N·m) @ 7500 rpm
* Transmission: S80
B18C6
* VTEC
* Found in:
o 1998-2001 Honda Integra Type Rx
* Power: 200 hp (149 kW), 136 ft·lbf
B18C7
* VTEC
* Found in:
o 1996- Honda Integra Type R (Australia)
* Power: 210 hp (149 kW), 136 ft·lbf
[sm=jawdrop.gif] WOW MAN, where do you find this stuff
Old Dec 12, 2006 | 01:05 PM
  #36
DCXgageman's Avatar
DCXgageman
Default RE: CRX?
Hehe, this is a funnie thread.
All I know is I raced a noisy crx this summer in my pt (w/150 hp sohc and around 3300#'s) and beat him. The pt is slow as heck, so the crx was a real dog.
Old Dec 12, 2006 | 03:42 PM
  #37
spudsterier
Default RE: CRX?
pt's are dohc's.....not sohc's....
the pt isnt terribly slow.....i think it does pretty good for the size of it and only having a 2.4
no i am not considering the magnum and srt-4....just the ones our cars had available without alot of modification
