Help with a 95 neon
Old Dec 9, 2006 | 10:40 PM
frenchdugay's Avatar
frenchdugay
Default Help with a 95 neon
New Blood here so be nice,
I have a 1995 Dodge Neon with a 2L 4 cyl SOC engine
96K on it.
The problem that it is having;
After it warms up at idle it starts to stumble. Even worse when its in reverse.
When you idle down from normal speed 50mph it like chugs just before it stumbles.
It has new PCM, new plugs, I have removed and cleaned the injectors.OBD II has no reading.
any ideas?
Old Dec 9, 2006 | 10:44 PM
fullbuilt's Avatar
fullbuilt
Default RE: Help with a 95 neon
it sounds like your car needs to stop drinkin
Old Dec 10, 2006 | 10:45 AM
mike9fore's Avatar
mike9fore
Is it loosing Power??? If not, NEED MORE INFO!
Old Dec 11, 2006 | 04:02 AM
Mean Green's Avatar
Mean Green
Well it looks like this has been moved here but why?
Old Dec 11, 2006 | 10:08 PM
Dazzellerr's Avatar
Dazzellerr
tps. almost 100 percent positive. sometimes they dont throw a code when they start to fail.
Old Dec 12, 2006 | 01:42 AM
das2123's Avatar
das2123
ORIGINAL: Mean Green
Because this is the Dodge Neon 1st gen forum....maybe
