UDP and Belts
Old Jan 5, 2007 | 03:59 AM
casper's Avatar
casper
Default RE: UDP and Belts
a few not much, maybe 1-2, 3 on the outside
Old Jan 5, 2007 | 11:44 AM
das2123's Avatar
das2123
ORIGINAL: QuiK615
Thanks for the help what kinda horse power will i get with this? if any[8D]
You won't gain HP, but rather free up HP. It will allow you to rev and accelerate quicker. I loved my MPx UDP. Easy as hell to take back off also.
Old Jan 5, 2007 | 12:53 PM
racerx55's Avatar
racerx55
i bought one of those $40 ebay pulleys, looks identical to unorthodox without the name engraved into it. been on there for 30,000 miles, really frees up power with the a/c on.
Old Jan 5, 2007 | 04:04 PM
QuiK615's Avatar
QuiK615
http://www.modernperformance.com/dcx...ne-trans.shtml
only 6 to ship next pay cheak ill get em might just take the 30 min drive
Old Jan 5, 2007 | 05:14 PM
das2123's Avatar
das2123
ORIGINAL: QuiK615
I didn't realize you were in Houston as well.
Old Jan 5, 2007 | 05:57 PM
QuiK615's Avatar
QuiK615
well Kingwood North east houston suberb
Old Jan 6, 2007 | 09:44 PM
spudsterier's Avatar
spudsterier
ORIGINAL: fullbuilt
ORIGINAL: spudsterier
if you have an impact and the right puller to get the stock crank pulley off.......
i shredded my alternator belt this morning.....had to leave my car about an hour from home.....took 6 trips to napa to find a new belt that would fit[&:].....then about 2 hours later i snapped my power steering belt....so tomorrow i have to go hunting for a new one of those too[:@]
you didnt happen to bend the lip on the pully did you
ive bent a few screwdrivers pretty good.....but thats it...
i used to break pullers all the time trying to get the pulley off....then i bought my little snap-on mini monster....best puller ive ever had and its made specifically for the neons....i would suggest getting one if you have an extra $120.00.....OTC makes one as well for about $50.00
Old Jan 7, 2007 | 04:11 AM
Ghost Neon 2's Avatar
Ghost Neon 2
ORIGINAL: fullbuilt
Do you have a part number or a specific name?
Old Jan 7, 2007 | 08:24 AM
racerx55's Avatar
racerx55
If you put a little heat to the center of the pulley it comes right off, take it off when the engine is 100% cold, put your puller on, put some pressure on it then warm up the center with a small propane torch just to get some heat in it. slides right off.
Old Jan 7, 2007 | 01:17 PM
fullbuilt's Avatar
fullbuilt
blue point part # ya9740a its the only one i ever used after finding out normal pullys woulnt cut it
