Is this Rod slap
Old Jan 9, 2007 | 07:19 PM
HabitatHxC's Avatar
HabitatHxC
Default Is this Rod slap
ok so I have been hearing about rod slap on the .org but no one responds to my question, Is this rod slap, Is it going to die =*(
Ive been driving it like this for 2 years its not much worse than it was back then.
http://www.youtube.com/watch?v=Cmz0RaJt2-Q
To me it sounds like rockers or something in the top end but towards the end of the video i lower the recorder below the bumper and thats when you can hear a lil knocky slappy knock knock sound i think.
Old Jan 9, 2007 | 07:24 PM
fullbuilt's Avatar
fullbuilt
Default RE: Is this Rod slap
sorry i just cant hear it right to tell
Old Jan 9, 2007 | 07:27 PM
HabitatHxC's Avatar
HabitatHxC
To me it doesnt seem to bad i just want someone elses oppinions, if i rev it lightly to about 2500 i can hear it when it idles down kinda like 5 or 6 knocks when its comming down, and its not too loud either...
Old Jan 9, 2007 | 07:59 PM
neoncrazy101's Avatar
neoncrazy101
almost sounds like our Sebrings injectors from that sound bite
Old Jan 10, 2007 | 02:52 AM
romeo21's Avatar
romeo21
you had better get that fixed cuse my neon sounded just like that and now im pulling the motor out so get it fixed fast
Old Jan 10, 2007 | 03:02 AM
Dazzellerr's Avatar
Dazzellerr
does it stay throughout the rpm band or does it go away/ worse? doesnt sound like a rod knock persay.
Old Jan 10, 2007 | 03:11 AM
AKA NEON MAN's Avatar
AKA NEON MAN
Ya it dosn't sound like rod slap some of the neons have really bad valve train here try this to see if the sound quits down a lil go buy some really thick oil and poor it in top of the valve cove and then let it run a little and see if it sounds a little better if not u might have a wore out valve train a rod sounds a little loude then that noise.
Old Jan 10, 2007 | 03:46 AM
AKA NEON MAN
do they sound like taps or knocks?
Old Jan 10, 2007 | 03:56 AM
sps20racer's Avatar
sps20racer
Before you go taking the motor apart, I would check your flywheel bolts to your clutch or torque converter(auto or man). Also while you are down there check to see if your flywheel moves a little bit and the crank doesnt. I had it that same noise happen to me and I ended up rebuilding the whole motor just because my bolts were loose thanks to the transmission shop. Good luck with that.
Old Jan 10, 2007 | 06:29 AM
unclemike's Avatar
unclemike
Rod slap? I heard of piston slap. Bad rod bearing would be louder at start up until oil pressure built. Piston pins? They do go bad.
