bought a new starter
Old Jan 11, 2007 | 04:01 PM
tdizz07's Avatar
tdizz07
Default bought a new starter
okay i was doin some research on how to install my starter or w/e and i was just wondering for some good tips so that i can make this as short and simple as possible so far all i found was that
-remove raidiator
-drain coolant
-remove battery and box
then will it be like all out in the open for me to get to??
Old Jan 11, 2007 | 04:11 PM
spudsterier's Avatar
spudsterier
Default RE: bought a new starter
it wont be out in the open unless you take out the intake manifold......its nice to take it out, but isnt needed
otherwise, it sounds like you got it down
Old Jan 11, 2007 | 05:22 PM
das2123's Avatar
das2123
Easier way way would be to remove the front motor mount and then remove the starter.
Old Jan 12, 2007 | 01:08 AM
neisg1's Avatar
neisg1
When I did the starter on my 1995I just removed the cooling fan assembly and took the starter out the top. You have to turn the fan assembly just so so to get it out (mine has A/C so bigger fan assembly). Unfortunately I don't recall if I had to remove the battery box or not but I don't think so. The manual says to take it out from the bottom which involves removing an engine mount, jack stands etc what a pain.
Old Jan 12, 2007 | 11:13 AM
das2123's Avatar
das2123
^^^ I can remove and install my starter in about 30-45 minutes.
Old Jan 12, 2007 | 01:01 PM
tdizz07's Avatar
tdizz07
hmmn, welll ill go out there and start if i have any problems ill let ya know lol
thanks
