ethanol in gas?
Old Jan 12, 2007 | 02:41 PM
asbel's Avatar
asbel
Default ethanol in gas?
my 97 plymouth neon has 202000 miles on it and its in relatively in good condition. what would happen if i put some stuff thats 95% methyl alcohol into my gas tank. would it cause any big problems?
Old Jan 12, 2007 | 03:01 PM
das2123's Avatar
das2123
Default RE: ethanol in gas?
It won't run probably.
Old Jan 12, 2007 | 03:38 PM
neoncrazy101's Avatar
neoncrazy101
just dont.
Old Jan 12, 2007 | 03:46 PM
asbel's Avatar
asbel
ok i wasnt going to but someone mentioned it here at the shop where i work as the "secretary". i didnt know if they were serious or not but thanks
Old Jan 13, 2007 | 07:35 AM
racerx55's Avatar
racerx55
i hope your not talking about E85.
95% methanol i think would run a little lean.
stick to the pump gas
Old Jan 22, 2007 | 12:01 PM
Scooby2306's Avatar
Scooby2306
i used to have a 95 mitsubishi galant 2.4 and i used to work offshore and i would get gallons of 100% methanol (liquid methane, and alcohol) and i would put about 12 oz in with a tank of gas and it worked pretty good it cleaned the fuel lines and injectors and also rids any water you might have in the gas. i also used this in my 79 pontiac trans am with a 6.6ltr 455 only i would add a gallon in with a tank and not only did it clean everything it boosted hp and shot pretty blue flames out the exaust
Old Jan 22, 2007 | 12:22 PM
shnormo's Avatar
shnormo
HAHAHAHAHA my friend Ethanol is corn alcahol. Alachol absorbs water thats why flex fuel parts cost so much more. Methanol is another form of alcohol. Therefore it is water absorbant. Another thing, ethanol doesn't have the same potential chemical energy as gasoline. So I would have to say that is a lie.
Old Jan 24, 2007 | 10:47 PM
Scooby2306's Avatar
Scooby2306
no its not a lie im being completly honest actucally they use a form of methanol in top fuel drag cars it burns quite nicely although during the day time u cant see the flame if burned alone and i did use it in my car and had no problems i wouldnt recommend using too much however because it will dry your seals and gaskets out and that can get pretty costly but if your engine is set up to use alcohol fuel you can us as much as u want
Old Jan 25, 2007 | 02:32 AM
71RoadRunner's Avatar
71RoadRunner
ORIGINAL: Scooby2306
[sm=bs.gif]The '79 Trans Am came with 2 different 6.6L engines, the 400 Pontiac or the 403 Oldsmobile engines, the 455 was NEVER an optionthat year or any of the years surrounding '79 and is far larger than 6.6 liters (the 455 is actually 7.5L). The '79 Trans Am with the shaker hood scoop with 6.6 litre on it were the 403 Olds engines which are boat anchors with only 185 whopping horsepower and the ones that had T/A 6.6 on the scoop were the 400 Pontiac engines with 220 horsepower.
Old Jan 26, 2007 | 09:58 PM
pimpberetta's Avatar
pimpberetta
Haha, I smell some ownage!
