cold starting problems
Old Jan 13, 2007 | 03:58 PM
reeperrobb's Avatar
reeperrobb
Default cold starting problems
hello all. I am new to this site, but used similar sitesbefore.any help would be much appreciated. I recently was just given a 97 dodge neon 4d and it is in vey good shape runs very good once it is warmed up but to get it started to warm it up is another story. it starts for a few seconds then stalls starts then stalls if I give it gas it stalls it does this for a few minutes.once it is warmed up it starts fine. I pulled 12, 22, 22, 42,55 from the key code method. I switched the relay for the horn relay and no change. I also know that the 22 code is from low engine coolant just noticed that one of the rad bars popped a hole!! but that shouldn't cause cold start problems should it? I am just wandering if anybody knows where to look next fuel pump etc. thanks in advance Rob
Old Jan 13, 2007 | 09:02 PM
das2123's Avatar
das2123
Default RE: cold starting problems
Code 22 isn't for low coolant but rather for engine coolant temp sensor out of range. Your CTS may be bad.
Old Jan 13, 2007 | 10:14 PM
reeperrobb's Avatar
reeperrobb
oh I didn't know.but thanks for the info I will check the CTS tomorrow thanks again I will keep the site posted thanks Rob
