bent Swaybar?
Old Jan 17, 2007 | 04:42 PM
neoncrazy101's Avatar
neoncrazy101
Default bent Swaybar?
Ok i was under my car taking measurements from the manifold to the end of the Cat. and i looked over and saw this.
so obvious the bushsings are bad but the other side isn't like that at all (bent that way) with the tires off the ground. but when i jack up that tire to where it would be for driving it became flat like so.
does that mean that the sway bar is bad? or just the bushings are bad which are causing it to do that.
Old Jan 17, 2007 | 04:46 PM
Neon_2ner's Avatar
Neon_2ner
Default RE: bent Swaybar?
Noticeable amount of rust where there's contact probably means that the bushings have been compromised, I believe they're supposed to make a seal. I could be wrong though. The amount of cracking on the rubber pieces would concern me as well.
Old Jan 17, 2007 | 07:14 PM
das2123's Avatar
das2123
Holy crap...get some new bushings!!!
Where'd you get the sway bat from?
Old Jan 18, 2007 | 12:38 AM
neoncrazy101
that sway bar is the factory installed on from Oct. of 94 lol same with the bushings.
EDIT: would the bushings from energy suspension be any good?
Old Jan 18, 2007 | 07:43 AM
FastNeon84's Avatar
FastNeon84
man i need to replace the same ones on my car...theyre about as bad as yours neoncrazy..but not rusted though...
Old Jan 18, 2007 | 11:22 AM
das2123's Avatar
das2123
ORIGINAL: neoncrazy101
I have heard good things about them.
