Key stuck in ignition
Old Jan 18, 2007 | 02:50 AM
michakaveli's Avatar
michakaveli
Default Key stuck in ignition
Anyone have the issue of having a key stuck in their ignition. Had a copy made this evening, unlocked the doors no problem, went into the ignition no problem but just won't come out... Any suggestions?
Old Jan 18, 2007 | 04:06 AM
neisg1's Avatar
neisg1
Default RE: Key stuck in ignition
If this is a newly cut key it may have some rough edges, I would try spraying some silicone lube in along side the key and see if you can work it out. Side pressure on the steering wheel can also jam the lock.
Old Jan 18, 2007 | 01:30 PM
michakaveli
ORIGINAL: neisg1
Any hints to where one may find some of this magical silicone lube? I assume AutoZone or the likes but you never know...
Old Jan 18, 2007 | 02:02 PM
asbel's Avatar
asbel
try turning the wheel back and forthe a little there might be a saftey lock on the key. if taht doesnt work
and aboput the secret lube yeah autozone/advance auto would be the place to go.
Old Jan 18, 2007 | 05:52 PM
Bassboy's Avatar
Bassboy
Just yank on it til it comes out... I did that with the key that came with my car and I can take the keys out while the car is running
Old Jan 18, 2007 | 08:30 PM
michakaveli
got the key out.... The ignition don't like the new key, will have to file it down some.
