Stuck Crankshaft Pulley
Old Jan 23, 2007 | 12:27 AM
rtneon67's Avatar
rtneon67
Default RE: Stuck Crankshaft Pulley
i did twic but i never new there was a right puller till i got on to this forum
Old Feb 3, 2007 | 09:40 PM
Jens17's Avatar
Jens17
It's off!!!!!
I used the right puller but it still wouldn't budge.
I used an impact wrench but it still wouldn't budge.
I tried using a torch to apply heat but was afraid that I would burn the car to the ground (not such a bad idea).
Since I broke a piece off of the pulley on my first try I was going to have to replace it anyway so I used my welder to lay a bead on the outside of the center of the pulley.
Smokin hot!!
The damn thing finally came off.
Thanks.
Old Feb 4, 2007 | 10:24 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
does anyone have this part number for the correct puller?
i fouund this one
http://buy1.snapon.com/catalog/item....e&tool=all
Old Feb 5, 2007 | 02:12 AM
das2123's Avatar
das2123
The one from Snap-on used to be part #YA9740B. The one from Autozone is 27139 and the one from OTC is #6727.
Old Feb 12, 2018 | 02:10 PM
Damon Lee's Avatar
Damon Lee
Thumbs up No need for special puller
Instead use a 6 inch socket spacer in you crank shaft Bolt hole a three arm puller tap on the puller as your tightening it. Worked like majic
