transmission help
Old Jan 22, 2007 | 08:13 PM
jdog08's Avatar
jdog08
Default transmission help
i am in the process of trying to install my new motor. I was trying to bolt back the transmission and i cant remember where all the bolts go because i was having my friend help me and he is sloppy and didnt pay attention to where they went. Also there is a little bracket that i know goes somewhere around the starter but im not sure where it goes so any help i could get would be great. Pictures especially.
-Justin
Old Jan 22, 2007 | 09:22 PM
fullbuilt's Avatar
fullbuilt
Default RE: transmission help
wow thats hard over the net with the bolts its trial and error from hear. and for the bracket get a pic but the closest bracket to the starer is either the tranny brace or the power steering brace
Old Jan 22, 2007 | 09:24 PM
fullbuilt's Avatar
fullbuilt
oh ya if you lost one they should be the same thred as the motor mount bolts to hit up home depo
Old Jan 22, 2007 | 09:30 PM
jdog08's Avatar
jdog08
i will try to get a pic of the brace tomorrow but i will give a description of it if that helps it has 2 small holes right next to each other then on the other end it has 2 bigger holes and between the 2 holes its curved idk if this helps at all but i tried i will get pics tomorrow though.
Old Jan 22, 2007 | 09:51 PM
fullbuilt's Avatar
fullbuilt
the bracket for the motor mount is kinda like what you described
Old Jan 22, 2007 | 11:11 PM
jdog08's Avatar
jdog08
well i know its not the piece that bolts to the front motor mount if thats what you are saying
Old Jan 23, 2007 | 12:13 AM
fullbuilt's Avatar
fullbuilt
theirs another bracket like that at the water pump. if that aint it i give up till you get a pic
