Rear Brakes
Old Jan 23, 2007 | 09:33 PM
FastNeon84's Avatar
FastNeon84
Default Rear Brakes
Can someone give me the listof the parts in need to do a rear disc brake conversion?
Old Jan 23, 2007 | 10:10 PM
spudsterier's Avatar
spudsterier
Default RE: Rear Brakes
ebrake cable, the rubber brake lines that hook to the calipers, calipers, rotors, and the read dust shield...
if you remove the rear tires...then remove the caliper and rotors.....look at the hub that left on the car....there are 4 bolts in a square shape right in the middle....unbolt those 4 bolts...
unbolt the ebrake cable from the bracket thats hold it to the car....(its underneath the car just outside the wheel well)
remove the center console and unbolt the ebrake....
pull the calbe ends from the ebrake handle..
reach under the car and pull the cables through the car from the outside....
unbolt the brake line from the metal junction box thats located on the front side of the ineer wheel well...
tada!!!
Old Jan 23, 2007 | 10:15 PM
FastNeon84's Avatar
FastNeon84
thanks for the detailed instructions, man i wish i lived near you so you can help me out!
Old Jan 23, 2007 | 11:59 PM
das2123's Avatar
das2123
ORIGINAL: spudsterier
Are you talking about the knuckle? If so, thats the easiest way to do the swap. Everything is still assembled together. Below is a pic of everything you need, minus the knuckles.
[IMG]local://upfiles/33897/D7895A8B830748AB914185C879E97E91.jpg[/IMG]
