compression/pcm?
Old Jan 24, 2007 | 07:29 PM
turbodneonracer96's Avatar
turbodneonracer96
Default compression/pcm?
I bought the mopar performance pcm Dohc for my Sohc. It works great,but my only ? is if i up my compresion by shaving my head will it still work with my computer because of the advanced timing the Dohc ecu puts in. By the way my cars a 1996. PLus im using a 95 cam when my head is done being shaved 25 thousandths.
Old Jan 24, 2007 | 08:20 PM
das2123's Avatar
das2123
Default RE: compression/pcm?
Yes it will work, but why didn't you just buy a SOHC PCM for your 96?
