Wiring harness issue need advice
well i got a new motor put it in and forgot to cheack harness...well completely different. the old one had a plastic intake and the new has a metal. And the old one had a 1 piece plug that goes to comp and new one has like 3 plugs into comp. should i change out the sensors and intake? or what?
you could just switch out the sensors...as well as the intake manifold...but there are alof of sensors that will need to be changed....
so thecar is a 95 and the motor is out of a 97-99?????
if you swap out the engine harness with one from that year motor, then you will also have to swap out some wires inside the car....
personally i think swapping the snesors and intake would be the easier way to go
