Tranny Swap
Old Jan 27, 2007 | 02:09 AM
Leonheart17240's Avatar
Leonheart17240
Default Tranny Swap
Just would like to know how hard it is to do the atx to mtx swap? and if there is a list of parts needed?
Old Jan 27, 2007 | 03:31 AM
fullbuilt's Avatar
fullbuilt
Default RE: Tranny Swap
its a royal pain in the a$$
Old Jan 27, 2007 | 04:06 AM
pimpberetta's Avatar
pimpberetta
The install is not all bad. I had never done such a job before, and it took about 2 days during the nights with a buddy. BIggest pain is aligning the tranny onto the engine. Needs to be ****ing perfect before it will slide onto the output shaft.
Part list from top of head.
Trannmission
Shifter Cables
Shifter itself
Transmission mount - tranny side
Axles. I only needed one for the drivers side IIRC. (Different splines)
PCM, to avoid check engine light
Clutch and flywheel (Upgrade of clutch could be scene, I used the clutch from the donor car and it rattles pretty good under a low rpm load, but it doesn't slip one bit)
Transmission support bar probably also
PRetty much all I can think of right now. Its basically pull out the old, drop in the new one.
Old Jan 27, 2007 | 01:09 PM
Leonheart17240
hey thanks just wanting to get rid of the auto when i go to turbo it.
Old Jan 27, 2007 | 07:51 PM
das2123's Avatar
das2123
ORIGINAL: Leonheart17240
Here is a complete list and how-to...
http://www.msu.edu/~lareseer/trannySwap.html
