manual window replacement
Old Jan 31, 2007 | 06:28 PM
redbyrd's Avatar
redbyrd
Default manual window replacement
'96 Neon - I am in the porcess of replacing the driver's side manual window system. The local autopart store did not have the manual system, instead the power. After looking on the net, it seems there were only a "pulley type system". I do not know the proper names for these items. I need the "sprocket- gear" looking system. I have got the inside panel off and the sprocket does not engage the large half moon gear.
help
redbyrd
Old Jan 31, 2007 | 06:47 PM
romeo21's Avatar
romeo21
Default RE: manual window replacement
check out www.autoloc.com they got lots of stuff to help you out good luck
Old Feb 2, 2007 | 05:26 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
window regulator i had to replace the driver side on in my crown vic works great now
i think it all one piece
Old Feb 2, 2007 | 07:25 AM
FastNeon84's Avatar
FastNeon84
ORIGINAL: redbyrd
help
redbyrd
just sounds like somrthing came loose.... a while back my window had a similar problem when i tried to roll it up....only half of the window would roll up and fall off track.....went to the glass place and got it fixed for 30 bucks
