Weatherstripping on driver's door
Old Feb 5, 2007 | 06:29 PM
koolaid117's Avatar
koolaid117
Default Weatherstripping on driver's door
Hi all! New to the forum here as I just got a 1996 Neon with 58k on it. The only real problem I've noticed other than the headlights is that the weatherstripping on the bottom of the driver's door is coming off. It appears that it is attached to the door with plastic fasteners that go through the weatherstripping and into the door and some of them are broken/missing. Here's my question:
Does anyone know where to get either the plastic fasteners or the weatherstripping or both? I've searched online and the only thing I can seem to find is the window weatherstripping.
Thanks for your help in advance!
Jim
Old Feb 5, 2007 | 08:22 PM
das2123's Avatar
das2123
Default RE: Weatherstripping on driver's door
Try a junkyard....probably your best bet.
Love the avatar and welcome to the forums.
Old Feb 5, 2007 | 11:14 PM
spudsterier's Avatar
spudsterier
you should just need the strip.....the fasteners most of the time just rip right through it
Old Feb 6, 2007 | 03:03 PM
koolaid117's Avatar
koolaid117
das, spud, thanks for the help. I will try the junkyard as soon as it gets warmer. Its about 1 degrees out!![sm=insomnia.gif]So, I'll wait. A couple of the plastic clips are missing. I'm thinking about some two-sided tape as a temporary fix.
Jim
Old Feb 7, 2007 | 12:51 AM
spudsterier
there arent many types of tapes that will stick to that molding...
i took a bunch of those clips off the last car that i parted out.....i just dont know what i did with them
Old Feb 7, 2007 | 08:19 PM
koolaid117's Avatar
koolaid117
ORIGINAL: spudsterier
If you find them in the next couple of months, let me know. I'd be interested in buying them![sm=signs003.gif]
Jim
Old Feb 8, 2007 | 01:32 PM
spudsterier
iknowi have the weather stripping too, maybe the clips are in it still
Old Feb 9, 2007 | 02:17 AM
koolaid117's Avatar
koolaid117
[sm=icon_cheers.gif] Any help is appreciated!!
Jim
Old Feb 9, 2007 | 03:14 AM
neisg1's Avatar
neisg1
There are weatherstrip glues avalable that should hold the strip on. "Permatex" makes one called "yellow super weatherstrip adhesive" pn #80BRor Adhesive - Super weatherstrip(Permatex weatherstrip Cement)pn #80S.
http://72.14.253.104/search?q=cache:...cd=1&gl=ca
http://www.partsamerica.com/ProductL...?Category=3238
I'm sure there are lots of other brands around too.
