AC pump locked up!!
Old Feb 10, 2007 | 04:44 AM
buzzbaker77's Avatar
buzzbaker77
Default AC pump locked up!!
My AC pump locked up today. I made it home with the belt intact (though I got a few looks). Can I just bypass the AC pump and not mess anything up? This pump is not that old, but it leaked when it was put on and I didn't need the air that bad. But someone said that it needs to have the coolant in it to stay lubed up. So I see why it would freeze up. If I could bypass it that would be great because I don't really need the air. Does that pump run anything else?
Thanks.
Buzz
Old Feb 10, 2007 | 05:03 AM
highlinedude's Avatar
highlinedude
Default RE: AC pump locked up!!
no the ac pump dose nothing but ac, i removed bouth pump and conpresser pluss lines diddnt really see a diffrence in performance, but your water pume will spin faster, i heard it can were out faster, i had mine off about 30,000 miles and no prob
Old Feb 10, 2007 | 05:52 AM
pimpberetta's Avatar
pimpberetta
Im curious as to how this makes your water pump spin faster. If your not lowering the amount of teeth on the water pump pulley, how will it spin faster?
Old Feb 10, 2007 | 06:09 AM
racerx55's Avatar
racerx55
it cant spin faster, the water pump runs off the timing belt
the AC belt has nothing to do with the water pump.
just get a 41 inch V belt to run the power steering and your good.
Old Feb 10, 2007 | 08:08 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
the only way you will change the speed of anything is a smaller diameter pulley. and AC is a crutch
Old Feb 10, 2007 | 04:47 PM
highlinedude
i ment p/s pump the belt travle has been made smaller
Old Feb 11, 2007 | 01:04 AM
pimpberetta
I'm not sure if you understand the theroy of ratio properly.
You haven't changed any pulley diameters or gear ratios. The belt being shorter will not make anything spin faster. The P/S pump will still rotate at the same speed as it did with the longer belt on it running the A./C also.
Old Feb 11, 2007 | 06:22 AM
highlinedude
ok thank you, do you know were i can a complete pulley kit??
Old Feb 11, 2007 | 07:37 AM
racerx55's Avatar
racerx55
What do you need a pulley kit for?
Old Feb 11, 2007 | 07:44 AM
highlinedude
4 my 98 neon?
