SRT injector?????
Old Feb 10, 2007 | 11:46 PM
turbodneonracer96's Avatar
turbodneonracer96
Default SRT injector?????
Are the SRT 4 injectors a bigger PSi than the stock 19lb injectors of the first gen. I need to get a bigger psi injector for my turbo setup, im on a budget like most of us !!!
Old Feb 11, 2007 | 02:07 AM
racerx55's Avatar
racerx55
Default RE: SRT injector?????
I dunno about Psi but the flow rating will be higher for sure on a turbo motor Vs N/A
Old Feb 11, 2007 | 02:44 PM
das2123's Avatar
das2123
ORIGINAL: turbodneonracer96
Yes they are and are rated at 47 lbs. They fit right in to the 97-99 neons, but if you have a 95-96 then you will need an adapter for the plug end.
Old Feb 11, 2007 | 02:47 PM
FastNeon84's Avatar
FastNeon84
kool where can u get those adapters from....maybe come out cheaper get the srt injectors than to get the accel 30lbs for $150
Old Feb 11, 2007 | 02:52 PM
das2123's Avatar
das2123
Youcan order them from RSautosports or get them from a junkyard...just get the plug and pigtail.
