Headlight question
Old Feb 12, 2007 | 07:23 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: Headlight question
why is HID so great that its that much?
Old Feb 12, 2007 | 07:38 PM
das2123's Avatar
das2123
ORIGINAL: DOHCgarrett t3
Because it's pretty to look at. You always know when there is a Mercedes or BMW coming up behind you in the dark because of the look of the headlights.
Old Feb 14, 2007 | 02:25 AM
neonracer1010's Avatar
neonracer1010
wth does HID stand for and what does it do?
Old Feb 14, 2007 | 02:30 AM
das2123's Avatar
das2123
ORIGINAL: neonracer1010
High Intensity Discharge. It provides a bluer and brighter look from the headlights.
Old Feb 14, 2007 | 06:36 AM
HabitatHxC's Avatar
HabitatHxC
What about these, they say there "brighter" than the apcs or are they still crap? http://www.modernperformance.com/dcx..._1995-99.shtml
Old Feb 14, 2007 | 11:34 AM
das2123's Avatar
das2123
ORIGINAL: HabitatHxC
I have heard good things about those lights. Light output is supposed to be great but they won't look like the "real" projectors lights.
Old Feb 14, 2007 | 04:31 PM
99 Neon's Avatar
99 Neon
i have the halo healights on my neon they were decently easy to install and the light output is really fine imo and it gives your neon a special diffrent look so it stands out more
Old Feb 17, 2007 | 01:29 AM
AIRBORNEREY578's Avatar
AIRBORNEREY578
HID HEADLIGHTS GIVE OUT A CRISP AND CLEAR LIGHT. THEY DON'T LOOK YELLOW ITS A CLEAR WHITE LIGHT. YOU CAN GET THEM OFF EBAY FOR LIKE 150 ALLTHE WAY UP TO 3,000 DOLLARS. THEY ARE ALL PRETTY MUCH BUILT THE SAME ALL YOU ARE GONNA PAY FOR IS THE NAME BRAND. AS FAR AS ( APC XENON REPLACEMENT BULBS GO) I WOULD NOT TRUST THEM. THEY ARE NOTORIOUS FOR MELTING HEADLIGHT HARNESSES AND LIGHTING CARS ON FIRE. THE REASON FOR THIS IS THAT YOUR CARS HEADLIGHT HARNESS IS ONLY MADE TO PUT OUT LIKE 45 WATTS LOWBEAM AND 55 WATTS HIGH BEAM ALL THE XENON BULBS DO IS DRAW MORE POWER ITS LIKE STICKING A 100 WATT LIGHT BULB ON A HOUSE LAMP THAT IS RATED TO MAX OUT AT 50 WATTS. THE HID ON THE OTHER HAND TAKE THAT 45 AND 55 WATT POWER AND THE CONVERTER BOX AMPLIFIES THE POWER FOR IT TO BE BRIGHTER. I HOPE THIS SIMPLE EXPLANATION HELPED A LITTLE.
Old Feb 17, 2007 | 02:34 PM
96 srt4's Avatar
96 srt4
hid?
Old Feb 17, 2007 | 09:07 PM
das2123's Avatar
das2123
ORIGINAL: 96 srt4
hid?
