wire question, im dumb...
on the like, 2 ft. hire harness that connects to the starter, there is a bigred wire that goes from the batterystraight to the starter...a small green that goes to the starter, and a big black wire, where does this go??? im thinking it goes on the bolt that holds the starter on, is that right???
That is the ground. It mounts between the starter and the transmission, one of the bolts that mounts the starter. If you laying down looking up at the starter, it would be the lowest front starter mounting bolt.
